Hi Guys
I just want to say whatever day you decide I am happy to make my ML1 Reverences that Chris has available. It should be a good match for the Bryston amps - it really does like valve stuff. I use the ones I have at home with a 15W Leben and will be using an 8W Trafomatic SET on their big brothers that are a bit more sensitive - 86 db is just a bit low for a SET amp - but their big brothers are 89db and I find thata just fine.
Bill
