I'm looking for a device that can remotely control my audio PC and is fairly easy to use for someone living in the digital age.
I know of the following options for controlling a PC in my sound room:
1- Buy and connect a touch screen for a PC in the room
a- This means I need to run a USB cable that would be very difficult.. and always connected to the touch screen.
2- Buy a remote-type PC that can control another PC... Like use a tablet PC and remote desktop or VNC to the audio PC.
3- I was wondering if you can VNC to another machine using an iPad... Then I can setup the audio PC however I want and just use the iPad's keyboard and touchscreen control to control the audio PC.
This may not be an option..
Another thought about the iPad is that I would want to set it up to control volume on the pre and other devices... But I doubt they have an IR sender.. I know Iphone/pods/etc. do not. But wow, what a great thing that would be if I could control the PS3 and preamp with the same device, wirelessly.
Running a USB to the touchscreen is the simplest route technically but most difficult functionally. Maybe I should just get over it and drill some holes.
What do you do for your audio PC controls?
