Author Topic: Caps  (Read 14565 times)
Caps
« on: April 27, 2010, 09:12:22 AM »
"What a difference a day makes" was a great lyric. Well same can be said for capacitors. My preamp was modified with two .1 dayton caps in a key coupling position [ Bad move what was he thinking. To my ears all was OK but I felt that I should be getting closer to life than I hear. WTF. All this great gear and still not 100% satisfied. So got the soldering iron out, found a pair of Auricaps from my amp [ Consonance] and went to town. Glad I did WOW ! so now the cap chase begins. Do I use V-cap copper, Audio Note, better Auri caps, Rel, oh my. The position couples the Cathode follower to the output tubes. The others are Rel caps. Any suggestions ?
  Anyway the sound is quite good now and was no slouch before so the nervosa begins. :duh
Re: Caps
« Reply #1 on: April 27, 2010, 09:36:03 AM »
Which Dayton caps? They make real foil caps in small values for bypassing, not metallized, supposed to be decent, but they only cost a dollar each made in chiner, less than grainy wimpy Solens from francais. But your Loesch is worthy of the very best...
Consider these:
DUELUND-025-71535 (200VDC, make sure that's enough!)
http://www.partsconnexion.com/capacitor_film_duelund_vsf_speaker.html - $145 each
North Creek Crescendo $9
http://www.northcreekmusic.com/CrescendoSpeakerCaps.html
Offline Face
Re: Caps
« Reply #2 on: May 08, 2010, 03:25:36 PM »
There are a pair of .1uf Vcaps for sale in the classifieds here, they would be a discernible upgrade.
Offline _Scotty_
  • “Sic transit gloria mundi”
Re: Caps
« Reply #3 on: May 08, 2010, 04:16:22 PM »
Somehow Dayton manages to make a bad sounding foil and film cap. Go figure. The Janzen caps from Parts Express are going to be a better choice. My choice for small value polypropylene foil and film bypass caps are Hovland Musicaps.
Offline topround
Re: Caps
« Reply #4 on: May 09, 2010, 04:18:07 AM »
My friend just took out his Auricaps and replaced them with the Jupiter HT's..he loves them, also the Crescendo caps are supposed to be great as well, althought they are large.
Auricaps just seem to do things right in my experience, they could be more extended on top and better bass but the mids are glorious. The Jupiters do what the auricaps do to a degree but with better extension at both ends, mids almost as good as the auricap.
Vcaps?  I would stay away, could be an expensive mistake. Charlie, you might be getting excited by the beautiful mids of the auricaps, the vcaps won't have that midrange weighty delisiousness of the auricap, they will have many other great things, depends on what your system needs really.
Mike
Re: Caps
« Reply #5 on: May 09, 2010, 04:40:22 AM »
Depends on what you want. If you can live with 500 hours of Jekyll and Hyde but want the most neutral, detailed (not overly so), harmonically correct, clean, etc. etc. - the Teflon VCaps are outstanding.
Couple them with some OIMP VCaps on the outputs and you're in heaven.
Re: Caps
« Reply #6 on: May 10, 2010, 06:29:39 AM »
  Ok heres the deal. V-cap copper Teflon for phono input, V-cap tinfoil for cathode follower and V-cap copper for output. The other choice would be Audio Note copper with a V-cap tinfoil for the cathode.
Re: Caps
« Reply #7 on: May 10, 2010, 06:46:59 AM »
I used the Sonicap Platinum for the input and the V-Cap OIMP for the output. Easy enough to substitute the V-Cap Copper for the input, but I agree with Brian that if you want something with a bit more midrange warmth and beauty then the OIMP makes for a good choice somewhere in the path. It is not mushy at all but definitely brings to the table some of what oil caps are known for in the mids.
As for the cathode follower, I'm not so sure you really need something as good as a teflon in that location. It's an expensive choice for that.
musicfile
Re: Caps
« Reply #8 on: May 11, 2010, 12:09:07 PM »
Interesting read
I'm thinking of gong with Rel Teflons in the input position and Jupiter Beeswax in the finals for my dodd amps
Any thoughts on this combo
I think this will be a better choice then sonicap plats
Any opionions
Re: Caps
« Reply #9 on: May 13, 2010, 06:51:01 AM »
Interesting read
Any opinions
  Different yes better who knows. talk with gary dodd. BTW are you looking for a neutral or colored cap ? If colored what flavor. Warm, bright, You also may want to try bypassing the existing caps first. Scotty may be able to help you out there. What caps are in the amp now ? Sonicap platinum ?
musicfile
Re: Caps
« Reply #10 on: May 13, 2010, 07:14:38 AM »
Interesting read
Any opinions
Thanks Charles for your replies. The dodds are quite neutral sounding  and I wanted a cap that gives it a bit of tone without messing up any of it's positive attribute Transparency detail
I currently have russian pio in the amp and they are far too dull and a good part of the high end is missing
The amp came stock with Sonicap GEN 1 and while these caps were very balanced I was missing a bit of the musicality that you get from a good oil
Which is why i'm thinking of going with a mix of caps
Gary really likes the Mundorf silver/gold in his amps not sure If I want to go that overboard in detail as I have vcaps in my preamp and have a very revealing and neutral speaker
Re: Caps
« Reply #11 on: May 13, 2010, 07:50:32 AM »
The V-Cap OIMP's might be right up your alley then.
shep
Re: Caps
« Reply #12 on: May 13, 2010, 08:10:21 AM »
These are going in my cdp. http://www.audioupgrades.co.uk/audioupgrades_cap.shtml
No user feedback yet. I don't really know what to expect.
musicfile
Re: Caps
« Reply #13 on: May 13, 2010, 11:37:34 AM »
I looked into the OIMP before and I don't think they have caps that small in size
I need .22 ironically I was looking at the Sonicap Plats as well for the input position
What electronics do you have this pairing in ?
Re: Caps
« Reply #14 on: May 13, 2010, 12:26:07 PM »
I used 1uF Platinums on the input and my original output caps were 5uF, so I opted for the 6.8uF OIMP's (although I doubt if there would have been any difference using the 4.7's).
Remember that smaller coupling caps will reduce bass output, depending on the circuit. I don't think you can be wrong with something larger, but you can be wrong with something smaller.
