Author Topic: Need a PC recommendation for plasma TV  (Read 3964 times)
Offline Rob S.
« on: February 19, 2010, 07:15:43 AM »
My current setup of stock PC into power strip plugged into another power strip (vansevers) produces bad picture w/ phantom shadow.
I need a roughly 12-14ft PC that isn't too thick or stiff since the back of the TV has limited room (recessed plastic box with maybe 3" of height).  A decent connector will fit, but the wire right beyond it must make a rather hard 90deg turn.   so does that disqualify the Pangea cord?
Rob
Re: Need a PC recommendation for plasma TV
« Reply #1 on: February 19, 2010, 07:25:03 AM »
Pangea. Price is right performance excellent.
Offline Rob S.
« Reply #2 on: February 19, 2010, 07:52:06 AM »
I hear ya, but the AC9 appears to be too thick to bend a good 90deg angle only 3" from the female connector end....  Is the AC13 thinner and more bendable?  would it be OK for TV?
« Reply #3 on: February 19, 2010, 09:02:44 AM »
  Yes it is and the 14ga. is fine. All my audio rejects PCs and conditioners]  now reside in the TV domain. The difference is so slight that I believe its all about shielding and EMI, RFI , rejection for video.
« Reply #4 on: February 19, 2010, 09:08:25 AM »
Black Sand's Black Max is 149 for 3m... and it's very flexible. John can make any length, and has done plenty for me... and is a sponsor here.  I'd highly recommend giving him a shout.
