Author Topic: Turntable Rewire  (Read 3529 times)
FrancP23
Turntable Rewire
« on: February 20, 2011, 10:53:58 AM »
While trying to figure out a ground problem with my Turntable I realized that when i changed cartridges I must have done some damage to one of the leads. Does anyone in the club rewire TTs, OR can anyone recommend someone for me to take it to? Thanks.
Offline topround
Re: Turntable Rewire
« Reply #1 on: February 20, 2011, 12:01:34 PM »
My friend Karl rewires arms.
I would reccommend the Cardas tonearm cable
If you can get to Jersey?
mike
« Reply #2 on: February 20, 2011, 09:42:24 PM »
  • Moderator
« Reply #3 on: February 21, 2011, 06:52:53 AM »
I would check with Scott.
http://www.sgcustomsound.com/services/index.htm
  He is DA MAN. Leads or TT wiring ? two different things, no ? check the connections again, sometimes the leads are not pushed in all the way or just loose and or dirty.
« Last Edit: February 21, 2011, 06:54:51 AM by rollo »
FrancP23
« Reply #4 on: February 21, 2011, 07:43:38 AM »
Charles,
Thanks. Someone else suggested Scott. I have an email into him. The wire from the ground separated from the cartridge clip. I tried soldering it back on the old clip with no success. Not sure I where to get a new clip. If I did I'd try that one more time.
