Author Topic: HeadFi Test disk  (Read 2817 times)
HeadFi Test disk
« on: November 08, 2010, 05:48:00 PM »
https://www.hdtracks.com/index.php?file=browse_music&type=label&id=158
"Head-Fi and David Chesky of HDTracks.com collaborated to assemble a headphone system test album called Open Your Ears (it can also be used to evaluate your non-headphone audio systems). CNET Audiophiliac blogger Steve Guttenberg wrote the liner notes to help the listener understand how to use the tracks to evaluate your system for:
Midrange tonalilty
Palpable detail and texture
Low-level resolution
Rhythm
Transparency
Spatial depth
Visceral impact
Depth
Out-of-head imaging
Bass extension
Center focus
Bass"
$9 for Headfi.org members
evan1
Re: HeadFi Test disk
« Reply #1 on: November 09, 2010, 08:59:03 AM »
going to order it when I get home from work
« Reply #2 on: November 09, 2010, 11:51:28 AM »
I wonder if they are going to make this available as a physical disc for those of us that don't run a music server.  Can downloads from HDTracks be burned onto a disc or is there some kind of copy protection?
« Reply #3 on: November 09, 2010, 04:16:13 PM »
Tom, you can burn a disc with downloaded tracks from HDTracks, they don't have any DRM on their music. But to make it playable in a CDP the tracks must be 16 bit 44.1kHz, so get that version if you buy it. Otherwise you have to convert the hirez files into redbook and 96kHz is not divisible by 44.1kHz, so dithering is required and you'll hear it.
