Hey Evan, if you're looking for more clearance after getting VTA and AS setup, there is a tiny hex nut you can unscrew to change the arm-lifter mechanism so you can get everything to line up with plenty of clearance. I just did all this... When you adjust one thing, it moves everything else out of whack a little.
The string/weight thing is a little challenging.
But I've been using the Pro-ject's for so long I forgot what 'easy' was like.
