Author Topic: Custom LeAnna preamp for Audio Nervosa member  (Read 2154 times)
Offline Response Audio
    • Response Audio
« on: January 30, 2014, 12:47:04 PM »
This preamp started out as just a wood chassis that was originally going to be used for a small tube amp. As you can see here, it ended up as a custom preamplifier based on the Musica Bella LeAnna tube circuit and heading to an Audio Nervosa Member to replace an older Musica Bella preamp.
Here is a list of features found in this LeAnna Custom:
Hardwood chassis
Real wood Mahogany inlays
Acrylic transformer/choke cover
Choke filtered power supply
High current toroidal transformer
Full polypropylene filter capacitors
Dedicated highly regulated DC supplies for tube filaments
Dedicated regulated DC supply for relay based source selector
V-Cap OIMP output coupling capacitors
V-Cap TFTF bypass capacitors
Solid core Copper/Teflon signal wire
Khozmo 48 step attenuator
High Low gain switch
Relay based 4 source selector
1 sets XLR input
3 sets RCA inputs
2 sets RCA outputs
Aluminum control knobs
« Last Edit: January 30, 2014, 12:48:57 PM by Response Audio »
Design Engineer
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
