Author Topic: Wyred 4 Sound's New DAC  (Read 15997 times)
Offline Face
Re: Wyred 4 Sound's New DAC
« Reply #15 on: May 17, 2010, 02:31:01 PM »
I tried it both ways (that sounds so wrong!)  :rofl:
:D
Well, the tube is only used in the preamp circuit, IIRC.  With the original tube, I barely heard a difference switching it on and off also.  With the Amperex I installed, the soundstage is slightly taller, otherwise there was barely any difference either.   :-s
Black Sand Cable
« Reply #16 on: May 17, 2010, 02:36:41 PM »
:D
I found the same thing myself which is too bad as I hoping for a lot more "warmth" when the tube was in use.
Offline Face
« Reply #17 on: May 17, 2010, 03:39:59 PM »
Was yours broken in?  Out of the box it is a little bright, but after a couple hundred hours it's very neutral.
Black Sand Cable
« Reply #18 on: May 17, 2010, 09:33:19 PM »
Yeah it's broken in. It sees a lot of use as my wife uses it in a living room system I have set-up for her.
pmkap
« Reply #19 on: May 17, 2010, 10:05:50 PM »
A tube output would have also been nice.  :o
Just out of curiosity...why?
The only reason I ask is that I recently did some testing with Peachtree's Nova. With 7 people in the room I played around bypassing the tube output and then adding it back into the mix and out of the 7 people in the room (8 if you count me) none of us knew when the tube was in use or not.
I just did the same thing yesterday with 4 people and again not one of them knew when the tube was in use or being bypassed.
I'm still floored as I wasn't expecting it but it really has me questioning a tube output on a DAC now.
Very interesting  observations. Martin (Acid Jazz) and I have been modding an EE dac with with switchable output stages, one, solid state and the other a tube anode follower. Although its quite easy to instantly switch between outputs, the output levels are slightly different, and the louder always sounded better.  :?
Luckily, my own dac has a slightly lower output than either, and the EE dac has a volume control that makes it easy to equalize volume between my dac and the EE, using either of its output stages. Matching the volume of the solid state output stage of the modded EE dac to that of my own dac, and switching between them in real time using the toggle switch on my CAT-SL1 to choose between the 2 line inputs, left us unable to differentiate between the two. This is not all that unexpected in that both modded dacs used the same opamp in their output stages. But the real surprise was that matching my dacs output level to that of the EE's tube output stage(with stock tube), also left us unable to differentiate between the two.
I don't know if assuming transitive equivalence is valid, but I do believe my system resolving enough and well sorted to be able to discern differences. Perhaps if the comparison was conducted with higher resolution source data (>16/44) the results might have been different. Yeah, I know Mike, I really should put that MTech dongle on line  :-P......
FWIW,
Paul
Black Sand Cable
« Reply #20 on: June 08, 2010, 09:33:11 PM »
For those still following along, the DAC-1 is now shipping on a regular basis and the DAC-2 is also shipping, but in limited numbers.
