Author Topic: Wife urging me to upgrade  (Read 42190 times)
Re: Wife urging me to upgrade
« Reply #30 on: March 03, 2015, 01:40:22 PM »
Bill, that's a nice preamp. I see they finally decided that a remote control volume does not hurt the sound quality. That used to be their excuse for not offering a remote control.
Offline StereoNut
« Reply #31 on: March 03, 2015, 05:10:41 PM »
Thanks, Perfessor!  I've been lovin' the Primaluna in my system. Extremely well made, point-to-point wiring, no need for hard to find or expensive tubes and, yes a remote! :thumb:
SN
« Reply #32 on: March 03, 2015, 06:16:36 PM »
Output impedance of the Prima Luna is 3kOhm, so the amp's input impedance should be >30kOhm. Bill's Moscode amp has tube inputs so it is OK, but many SS amps are only 10k and some amps, like older Odysseys were only 8kOhm.
Offline rpf
« Reply #33 on: March 03, 2015, 07:17:37 PM »
A Modwright, as has been suggested, would of course mate well with your amp. I owned the 9.0SE and the 36.5 (single box) and the former was very good while the latter was excellent.
The 36.5 in particular was very quiet and highly resolving. More so, as both my friend and I remember, than his ARC Ref 3 (in his system with Vandy 5As). It doesn't have a phone stage however, unlike the LS100 which has an optional MC.
A possible drawback if your Modwright amp and pre both have teflon caps is that the sound may be too smooth and slippery. But you possibly substitute some copper foil caps to balance it out.
Offline StereoNut
« Reply #34 on: March 03, 2015, 07:53:39 PM »
Here's what I found on the Moscode 600, Rich
Offline StereoNut
« Reply #35 on: March 03, 2015, 07:56:23 PM »
And the PrimaLuna ProLogue Premium Pre-Amplifier
Specifications
Gain: 12dB
Freq. Response: 4Hz-85kHz +/- 3dB
THD: Less than 1% at full power
S/N Ratio: 109 dB unweighted
Input Sensitivity: 200mV
Input Impedance: 100k Ohms
Output Impedance: 2800 Ohms
Power Consumption: 46 watts
Dimensions: 14.5 " x 8" x 15.5" (WxHxD)
Weight: 37.5 lbs
Inputs: 4 pair RCA / 1 pair HT bypass
Outputs: 2 pair RCA preamp outs / 1 pair RCA fixed tape out
Tube Compliment: 4 - 12AU7, 2 - 5AR4
« Reply #36 on: March 03, 2015, 09:36:48 PM »
As expected with tube input stage, very high impedance...  247kOhms   :thumb:
Offline StereoNut
« Reply #37 on: March 04, 2015, 05:21:11 AM »
That's good, Rich.  'Cause I wouldn't know a kOhm if it jumped up and bit me! :rofl:
SN
« Reply #38 on: March 04, 2015, 06:16:43 AM »
Slippery?! I know what smooth sounds like (good) slippery? I'm not so sure what that sounds like. I am definitely not going at it with a soldering iron. (Not that I am not capable with one I just don't want to get into mods at this time.)
Offline rpf
« Reply #39 on: March 04, 2015, 06:50:56 AM »
Overly smooth, lacking texture. Might not be an issue with the LS100 with it's richer 6SN7s.
« Last Edit: March 04, 2015, 06:55:47 AM by rpf »
« Reply #40 on: March 04, 2015, 07:11:26 AM »
there is a used 9.0 available but I don't think it would be a jump up. i think a 36.5 would be the minimum i would have to go to.
« Reply #41 on: March 04, 2015, 07:29:19 AM »
It might bite you if you don't understand it! Here is a quick lesson.
http://www.soundonsound.com/sos/jan03/articles/impedanceworkshop.asp
Input impedance (load) determines how much current the input requires to be driven without distortion. Output impedance (source) determines how much current the amplifier can deliver to a load.
To assure the amplifier has adequate headroom and the signal is transferred with no harm, the rule of thumb is that the input impedance should be 10x higher than the output impedance. The ratio of your preamp to amp is 100x  :thumb:
Often, the best sounding tube preamp circuits have high output impedance, and that is fine because they are intended to drive tube amplifiers which have extremely high input impedance.
It is possible to make a tube output stage have a very low source impedance, like a White Follower circuit as used in Manley Shrimp with 50 ohms, same as an opamp. But they don't always sound as good as traditional tube circuits like cathode follower which has higher output impedance.
« Last Edit: March 04, 2015, 07:33:16 AM by richidoo »
Offline rpf
« Reply #42 on: March 04, 2015, 07:34:27 AM »
[quote author=jimbones
[/quote]
Probably just require changing two coupling caps.
Offline Werd
« Reply #43 on: March 04, 2015, 07:39:45 AM »
I have never had this in house but every time i hear it sounds awesome. And everytime i am in the mood to buy one there is never one available.
The copland 305
http://www.copland.dk/cta305/
Offline toobluvr
« Reply #44 on: March 04, 2015, 08:29:05 AM »
Keep an eye on Canuck Audio Mart.  More likely to see Copland (and British / European) gear there.  I use a Copland hybrid integrated in my bedroom system on a pair of JM Reynaud Twins Signature.  It is excellent.
« Last Edit: March 04, 2015, 08:31:02 AM by toobluvr »
