Author Topic: P.I. audio group power conditioning thread...  (Read 4318 times)
Offline dBe
« on: November 30, 2019, 10:14:56 AM »
Tom Mallin is a customer of mine.  He has a dedicated niche in the What’s Best forum and is a prolific writer.  His BUSS experience thread is a treatise on his experiences with the UberBUSS And the BUSS-Stop.  It is an interesting read and I’m quite pleased with his findings.
If you are interested:
https://www.whatsbestforum.com/threads/my-clean-power-adventures.28053/
Offline Folsom
Re: P.I. audio group power conditioning thread...
« Reply #1 on: November 30, 2019, 11:44:07 AM »
He sure is! That's all the feedback one could ask for I imagine.
« Reply #2 on: November 30, 2019, 06:21:17 PM »
Congrats, Dave!
« Reply #3 on: December 01, 2019, 03:12:59 PM »
Thank you, Dave. That’s a very thoughtful and informative read from Tom and very much appreciated. I hope to have your latest AC outlet installed by the contractor this Tuesday.
Offline dBe
« Reply #4 on: December 01, 2019, 09:10:14 PM »
:thumb:
« Reply #5 on: January 16, 2020, 07:56:02 AM »
  Good to read about someone who agrees. For years I have been advising to separate Digital from Analog with dedicated lines as described. Adding an UBER on each line further improves the Sound. Then adding that Buss Depot is the icing on the cake. I use [4] dedicated lines all conditioned. At least change your receptacles.
« Reply #6 on: January 16, 2020, 05:09:47 PM »
I am vacationing. When I get home, I’ll be installing the new receptacles in my Uber 👍
« Reply #7 on: January 17, 2020, 08:26:47 AM »
i've not gone that extreme, but i have definitely gotten improved sonics from plugging my dac, transport and preamp into separate isolation transformers...
doug s.
   Do not Isolation transformers lift the ground ?
« Reply #8 on: January 17, 2020, 09:57:16 AM »
i suspect those w/3-pronged plugs and outlets don't, but i'm not the expert.
doug s.
doug s.
   They have a three prong plug however I believe the ground is lifted internally. Oh Dave help us out here.
« Reply #9 on: January 17, 2020, 10:07:03 AM »
Some Isolation transformers are floating output with a case wire to ground.
Others are 60v-0v-60v where the center tap of the output  is ground.
« Reply #10 on: January 17, 2020, 10:42:03 AM »
  Thank you Mad Scientist. :thumb:
Offline Folsom
« Reply #11 on: January 17, 2020, 12:37:21 PM »
60/0/60 are balanced transformers.
The ground incoming to the transformer is often tied to the center tap. Maybe always, I haven't seen the inside of more than a few.
« Reply #12 on: January 17, 2020, 03:03:23 PM »
Yes, and from what I read, now no longer supported by the electrical code for home use.
I have an old Equi=Tech 2KVA balanced output unit that worked well before it died.  Very quiet system with it.
