Author Topic: rivercable.com  (Read 5183 times)
  • Moderator
rivercable.com
« on: January 25, 2010, 10:29:45 AM »
  Check them out men. well made, inexpensive and measure very well. they can even match the inductance for your amps needs. cool.
« Last Edit: January 26, 2010, 07:53:01 AM by rollo »
Re: rivercable.com
« Reply #1 on: January 25, 2010, 12:38:58 PM »
Looks OK on paper. Has anybody out there heard them?
Re: rivercable.com
« Reply #2 on: January 25, 2010, 02:08:29 PM »
That is utmost importance!!! Specifications do not necessarily indicate good fidelity... Ever hear that transistor amp with maximum 0.02% THD??? Sounded like nails on a chalkboard as far as musicality...drive you from the room!!!
Re: rivercable.com
« Reply #3 on: January 25, 2010, 02:14:00 PM »
What do you mean that transistor amp? I've heard dozens that sounded just like that.  :rofl:
Offline Lizard_king
Re: rivercable.com
« Reply #4 on: January 25, 2010, 03:03:08 PM »
Has NE1 tried these yet?
bacobits
Re: rivercable.com
« Reply #5 on: January 25, 2010, 04:58:23 PM »
Some of the cables are Canare and the same for the terminations.
That is why they are priced reasonable.
What is the big deal? At least they admit it not like MAC cables that got caught recently.
I have used Canare in the past and they are good.
D
Offline RussL
Re: rivercable.com
« Reply #6 on: February 14, 2010, 02:10:29 PM »
D
  What happened with MAC cables?
  • Moderator
Re: rivercable.com
« Reply #7 on: February 15, 2010, 07:26:00 AM »
It depends on your outlook. First his cables are very reasonably priced. He uses Canare wire. The wire helps but is not the key factor. The Connector and method of connection weighs more IMO. He uses ERS product as well. For me no big deal. It was not a secret. He just did not advertise the wire.
  There are many manfs out there who use OEM wire. It is how the final product sounds not which wire. Now if he was charging a $1000 or $2000 then he deserves a spanking. However that is NOT the case. My 2 cents.
Offline mfsoa
Re: rivercable.com
« Reply #8 on: February 15, 2010, 07:50:38 AM »
I think MAC got a bad rap too.
People were slamming him for not owning the mine where the copper came from (OK, hyperbole I know)
I don't think there was any deception on MACs part - more of a lack of understanding on the mfg process by his critics.
-Mike
Offline Face
Re: rivercable.com
« Reply #9 on: February 27, 2010, 06:50:23 AM »
The termination looks cheap, no thanks.
