On the first oak baffles for the FPS drivers, they needed pilot holes in them to start the process. The #4 wood screws would not accurately start. My pilot holes with the hand drill were all over the place, but worked after some coaxing.
Since this oak baffle is already finished, want to protect it from my abuse, so the Dremel tool drill press and drilling guide should work. Once I make the holes, have a nail set to get the center, then do the drill.
Now to find my calipers to do the measurements.
