Author Topic: Tweak of Tweaks  (Read 31408 times)
Re: Tweak of Tweaks
« Reply #30 on: February 19, 2015, 06:39:57 AM »
Isn't that going to result in a syrupy sound?
(sorry, I couldn't resist)
    Good one Bob.  :rofl:
Offline satfrat
Re: Tweak of Tweaks
« Reply #31 on: February 19, 2015, 09:34:14 AM »
Dave Elledge of PI Audio has assured me his UltraBuss can handle cleaning up the sticky syrup leaving only a sweet maple sound. Hey, it's a Vermont thing.  :rofl:
Offline Emil
Re: Tweak of Tweaks
« Reply #32 on: February 20, 2015, 07:00:34 AM »
Looks like I found just what I was looking for here, Natural Glacier Crystal, refreshing blue Himalayan salt lamp. I bought 2 lamps and will be placing them on top of my main Lorelei loudspeakers which are next to all my electronics. Let them negative ions interact with my electronics positive ions.
Thanks Charles & Tom for this enticing tweak! :thumb:
Cheers,
Robin
Satfrat
So how long does it take before the air is ionized?
« Last Edit: February 20, 2015, 07:17:28 AM by Emil »
    --Ice Cube
Re: Tweak of Tweaks
« Reply #33 on: February 20, 2015, 07:53:42 AM »
  Hard to say with lamps. I noticed a difference after one day being on 24/7. A commercial Ion generator works almost immediately. The lamps offer a low output.
   A c
Re: Tweak of Tweaks
« Reply #34 on: February 20, 2015, 10:20:17 AM »
   A c
I'm not sure if is the output of the lamps as opposed to how the work. The salt crystal gives off ions when it heats up. I think you don't hear much of a difference before it has been on for a day simply because it takes quite a while for that little night light bulb to raise the temp of that big rock.
Offline Werd
Re: Tweak of Tweaks
« Reply #35 on: February 20, 2015, 11:18:57 AM »
Aha! I do have one. It isn't a rock but an ionize air filter, it oscilates too.
Got it going by my gear. I should have this anyways for dust filtering around my system. I like it so far for dusting i hope it makes a diff sonically. Good call on this one for preventative maintanance alone.
Re: Tweak of Tweaks
« Reply #36 on: February 20, 2015, 12:34:32 PM »
  Tom I use a 14W bulb not the 4W night lite ones. Heats up pretty good.
   Werd you should hear a more open sound and better defined imaging.
Re: Tweak of Tweaks
« Reply #37 on: February 20, 2015, 01:45:00 PM »
Even with a 14w bulb it will take a good amount of time to change the temp of the crystal through and through.
Offline satfrat
Re: Tweak of Tweaks
« Reply #38 on: February 20, 2015, 01:54:57 PM »
Cheers,
Robin
Satfrat
I think it takes about a decade,,,, maybe 2.  :rofl: These blue glacier salt lamps use a blue colored bulb. Unlike Charles lamps, it take a special type salt rock lacking in minerals that will allow colored bulbs to shine through it. Even then, these lamps use a 25 watt bulb, both for the light to shine through and to give off enough heat for the essential oil diffuser.
Science says these salt lamps won't ionize crap. But owners feel otherwise. I think that in itself qualifies salt lamps as a bonafide audiophile tweak.  =3o  :rofl:
Offline ejk
  • Did I say no dropouts ?
Re: Tweak of Tweaks
« Reply #39 on: February 20, 2015, 02:04:13 PM »
This is a link to a device like the Acoustic Revive RR777 that Topround and I purchased a few years back for only 165.00.
http://new.audiogon.com/listings/sw1-rr-77-schumann-resonance-rr77-rr-77--7
It doesn't look like it is sold anymore
Offline satfrat
Re: Tweak of Tweaks
« Reply #40 on: February 20, 2015, 02:35:27 PM »
Evan, while that device might be similar to the RR-77, it is nothing like the RR-777 which is said to be 4 times stronger than it's predecessor. And the RR-888 is said to be a step above that Evan.
Cheers,
Robin
Offline ejk
Re: Tweak of Tweaks
« Reply #41 on: February 20, 2015, 04:52:21 PM »
Typo Robin rr77.
Re: Tweak of Tweaks
« Reply #42 on: February 21, 2015, 08:13:50 AM »
  The $165 one is equal to the first offering by AR. Since as Arafat has stated is 100% correct. The originals are affective. We found two worked wonders. One placed by components , one at rear of room.
   I think our resident professor Richidoo needs to build one on the cheap. Go get em Richidoo.
Offline Emil
Re: Tweak of Tweaks
« Reply #43 on: February 21, 2015, 11:20:43 AM »
Its about the only thing Arafat and Yitzak Rabin could agree on :rofl:
I crack myself up sometimes.......
    --Ice Cube
Re: Tweak of Tweaks
« Reply #44 on: February 21, 2015, 12:53:24 PM »
No new age technology for me, been there done that.
My favorite tweak is a good night sleep and a belly full of vegetables. Mind is the most important component in any audio system, but also the least understood and most neglected.
