Bill how many tubaroonies in the Moscode [5] ? What types ? I agrre with Carlman and Joe. Prudent to wait, lets see how long you can put off the nervosa.
Hi Charles
Sorry for such a delay in answering this. I just couldn't find the right scrap of paper with the notes I wrote down from one of my many conversations with George Kaye until now.
The N.Y.A.L. Moscode 600 has 7 tubes in it as follows:
• The two outer-most tubes are 6GU7's as Diff. Voltage Amp tubes, I think?
(George says that using 6FQ7's here can sound a bit harsh.) 6H30's can be another upgrade choice, but they're much more $$$ expensive.
• The 2nd. tubes in from each side (counting from the outside/in) are also 6GU7's as Cascode followers. There's a matched quad of them in my amp. (George said that using 6FQ7's in this position is acceptable, unlike the outer most tubes described above.)
• The next tubes in line are the BIGGER 6LU8's, which are High Voltage regulator tubes.
• Lastly, the one middle tube is a 6DJ8 as a volt Regulator.
I hope this helps answer the question for you. Oh, BTW - I have not even thought of rolling any tubes yet!!!
SN
