Round #2I was lucky enough to have a few buddies come over my place yesterday with more equipment to "mix 'n match" into my system. We started off by listening to my system intact as a baseline and then started some comparisons.
We swapped in a Miracle Audio all SS pre-amp into place to run with the borrowed Classe' "Twenty Five" that I still had in the house. The Miracle pre was a BIG improvement over my old Parasound PHP850. Compared to the Parasound, the Miracle Audio pre had a bigger soundstage, better detail and more "air", so we kept that (Miracle) pre in place for the rest of our separates comparisons.
Next up, was a pair of Arion Hybrid Monoblocks. We hooked everything up and all of a sudden had NO music from the right channel! After re-checking all connections, swapping cables back 'n forth and a lotta "head scratching", we still couldn't figure out what was wrong...??? We solved the problem when we noticed a flash of light at the top of my CD player and that tell-tale burnt electronics smell waffed through the air! A final puff of smoke rose from the vent holes as I pulled the power cord. Talk about bad timing!
At that point, just to eliminate any other possible source of any other problems, we removed my Headphone "switch box" that was hooked up between my speakers and amp. (My Naim electronics don't have a headphone socket!?!?!) We still needed a new source - so I ran upstairs to pull an older and cheaper (D500 SE) Cambridge CD player that I had in a second system upstairs. We hooked up the D500 SE and we continued our (obviously disrupted) listening. There was lotsa extra "horsepower" here with the Arions. They gave us everything the Classe' did, but even more dynamics and bottom end slam. A very nice combo; albeit one that was too expensive for my budget.
We then decided to use the Cambridge D500 SE CD player as a Transport only and hooked it up to a borrowed EE "Dexa" DAC. This sounded every bit as good as my Cambridge 840C Azur player as a stand alone CDP (before it went up in flames!) and probably better. (I still was a bit distracted over my 840C dying on me, so I'm not totally sure about this.) Anyway, we were all pretty much enjoying the music with this set up until everyone's appetite started to override the need for audio! While I got the "eats" together, I asked one of my friends to re-connect my Naim gear just so I could have some peace of mind that it was only my CD player that was effected earlier.
Well, I was very thankful that all of my remaining electronics were working just fine - thank God!
Matter of fact, that was when we all realized just how much of a positive effect there was by removing my "headphone switch box", because my Naim system sounded so much bigger and better. I forget who, but someone said it was like my system swallowed a handful of steroids between the first listen to it and now!
The last change for the day was swapping in the Rogue Cronus Magnum Integrated with KT120's in it to replace my Naim stuff. We set things up and let it play some "dinner music" to warm itself up while we ate. After eats, we listened to what tubes sounded like in my system for the very first time. It sounded great. Plenty of power (more than I thought before actually listening) and a midrange that was gorgeous! A rich, lush sound all around.
Now, if I could just keep the detail, P.R.A.T. and an extended top and bottom end of my Naim electronics and combine it with the beautiful mids and natural decay of the Rogue tube gear, I'd be in Audio Nirvana!!!
SN
