I am going to play devils advocate here in regards to the ML No.53. What if the amp is more or less a GIGO device. If anything goes in with something wrong with it, it is just going to get louder and more aggravating to listen to when it comes back out. Yeah that's going to be fun.
Both the Revel Salon II and the JBL Everest have 24db/oct crossovers and higher order networks can ring under some operating conditions. I suspect the ML No. 53 can probably hit a loudspeaker hard enough to make both drivers and crossovers ring. Also the Revels aluminum cones could be excited enough that the out of band resonance the drivers have at the cone break-up frequency could be
generating a good dose 3rd harmonic distortion which occurs within the drivers passband even though the resonance lies outside upper cut-off frequency.
In any case neither of these speakers would be my first choice for pairing with this amplifier. The other possibility I already mentioned is an existing problem upstream of the amp being passed straight through the amp and into unforgiving speakers.
The amplifiers might only be the messenger bearing bad tidings.
On the issue of "tone", I don't know what an accurate reproduction of "tone" sounds like when the term is applied to reproducing recorded music. It's always so altered by the recording process;(ie. microphone colorations, the A to D converter, manipulations by the digital mixing console, which could be state of the art or sound like crap, etc,etc,etc.) that I don't know what right might be in regards to a particular recording.
I have heard some switching amplifiers that sound harmonically thinner than their Class A or Class AB counterparts and I prefer the sound of the conventional amps when I encounter this problem with a switching amp. But this is still a case of my making a value judgment, in absolute terms I may be full crap and have only chosen what I like to listen to.
I think a closer listen to the ML No.53 under controlled conditions, say in ones own system, might yield a more definitive answer as to whether the emperors' new clothes are really there or not.
