Hi Steve
Just to play the idiot here for a minute (nothing new), I mean this more as a technical question than as a wisecrack, although I know it will sound more like the latter:
If you can't hear the difference with a preamp in or out of the system, why do I need it? Especially if I know I don't need any additional gain?
Again, not meant to rock the boat, but a technical question phrased particularly poorly.
I Rich,
Not a wisecrack at all Rich. A line preamp allows one to select what source and give voltage gain and then feeds to the amplifier, hopefully without colorations or distortions.
My preamplifier does this without altering the sound, coloring it. One has to be concerned with alot of sonic traits, such as dynamics, tonal balance, texture, focus, depth, width, soundstaging etc.
With the testing done so far, the 11A is so pristine and pure that what music goes in, exits the preamplifier without being altered. What goes in comes out the same without colorations, distortions. In otherwards, it is extremely clear, transparent, without adding any colorations, affecting dynamics etc.
Why do you need a preamp if you do not need the gain? "Especially if I know I don't need any additional gain?"
I was responding to DU. "I just don't want made worse."
You don't since you are using an integrated amplifier, as your active preamp stage is incorporated into the amplifier itself. Why add an extra stage to a system that doesn't need it?
There are two drawbacks with an integrated amp.
1) Frequency dependent feedback through the power supply.
2) The manufacturer designs the amp first, then make the included preamp fit. The quality of the entire assembly is dependent upon the quality of the amp.
Separates allows one to design the preamp first, as it is the only component that can actually be compared to a straightwire. Then the amp is designed afterward. This results in less compensation, thus better synergy.
I do not know any other company that does this.
ps. Here is a comment Martin made in issue 177 before the PBN Olympia-L preamp (12 grand) landed on the scene. It involved the system using the 11A, and using the new LessLoss power cords.
"The Big Rig had become something better, more musically truthful than any system I had ever heard... anywhere... anytime."
Hope this helps.
