Thanks guys. The Pipes have a sensitivity of 96db. at 6 ohms. They cross over at 65db. Actually my dream Amp is a Joule electra "Rite of Passage". Easy on tubes but expensive.
Yes Richadoo I really do like the SET sound with the Pipes. It has been so long since they were working [ F#@$%*&^(*&^%^*& ] OK better now , that the Nervosa was rising.
Rob the Atmosphere might be a good try. I'd give it a listen. Porzilli used a Melos tubed monster with 200 W plus with the Pipes in his home. Even though the speakers are 96db efficient there are a lot of drivers. [9] midbass and [24] 1" dome tweeters. That is mucho air to push. The AR 250 with 240W of triode juice was awesome but that tube rush was soooooo audible it had to go.
So re tube the AR for about a grand ? Re tube the Classic 60 ? Use the Cyber 211 ? Sell them all and buy a Joule Electra ? The SS amps that I am considering are Plinius, Edge, Pass, MBL and Dartzheel.
It will be fun trying but something tells me that the SET sound will be hard to better [ for me ]. It is addictive. I should have bought the Carey 211 amp
instead of the Cyber 211 and all this would be moot. One dumb f**k. Let the games begin. Will I be Braveheart [ SET], Gladiator [ Push pull] or Pee wee Herman [ SS].
