Author Topic: TRUTH in AUDIO  (Read 10382 times)
Re: TRUTH in AUDIO
« Reply #30 on: March 30, 2015, 09:40:44 AM »
  I own the "Complete Sonatas" good recco there Jason.
Offline Werd
Re: TRUTH in AUDIO
« Reply #31 on: March 30, 2015, 09:24:15 PM »
Don't be dazed and con FUSED. Fuses are great tweaks
Re: TRUTH in AUDIO
« Reply #32 on: March 30, 2015, 09:31:41 PM »
Re: TRUTH in AUDIO
« Reply #33 on: April 01, 2015, 08:06:39 AM »
   Yep dem der fuses can make a difference. Audio Magic leads the league in price and function. Synergystic up next. Different sonic results from both manufactures.
   They are getting exotic using Bees wax and nano fluid. Overkill ? hype ? The standard Bussman sand filled that is is better than standard but not equal to the others. Yes the prices are hard to swallow however the results IMO are worth the expenditure.
