I have a great old tuner, McIntosh MR-65b that's been completely overhauled. I can't wait to actually hear it... but, I don't know what to do about an antenna. I have an extra run of coax to my attic where I can install an antenna, then run it to the coax jack behind the hifi.
Couple questions...
What kind of splitter do I need to go from a 75?ohm coax to whatever the Mc likes... which has screws. Is it something like what you used for coax to the screws on a pre-cable-only TV? Would I be better off with something inside?
Also, what kind of antenna is good? Are there good brands or certain qualities to look for? i.e. should I avoid any particular materials, look for certain kinds of grommets, etc... I need it to work a long time and do its job well.
Thanks for any advice,
Carl
