To threadjack Mike's thread a little, did you get the original Octave or the MKII? If original have you tried 24/192 on it?
Thanks Mikef,
- Mike S.
Mike, I got the original. According to the guys at Metrum, the Mk II uses the USB implementation of the Hex, but apart from that it does not sound different from the original. Also,the Mk II is much more $$$, especially with the Mk I on special sale pricing.
I don't have any 24/192 files to try, so the answer is no.
I'm currently using SPDIF out from my Squeezebox Touch, and I think it sounds great. Very organic, great detail but smooth, not at all edgy, etc. I'm planning to try a W4S uLink USB-SPDIF convertor in the next month or two to see if it adds any improvement to the mix, which I believe it will.
