Rich, never owned Audience (at least to the best of my recollection which isn't all that great of late
). I've compared the Veloce to a Granite Audio and Grover and it clearly bested both.
I have tried a JPS SC3 digital IC and it also was clearly better than the Granite and Grover, but never had a chance to compare it with a Veloce. But the JPS is also a good bit more expensive than the Veloce.
My 2 cents... if you're looking for a digital IC (RCA or BNC) and you can live with just 1.2m length then the Black Cat Veloce should be on your try list... great price and eval period.
