Yes. I need to see a link or some pics because I'm stumped. So if your preamp has a phono ground lug take a wire from that phono ground and connect it to a negative post on your speaker? Wouldn't this invite a ground loop? Now my Jolida DAC has a ground lug which is closer to my speakers could I connect a wire from that lug to a negative speaker terminal and create the same affect?thanks
I think you'll find something like this over on A/C. It was a while back.
I'll give this a shot later with one of the wires from some Belden 5200UE cable that I found in my basement.http://www.belden.com/techdatas/english/5200UE.pdfSo a single 11" stripped copper wire attached to the phono lug of my preamp to start. This should be interesting. I'll take a picture when I'm done. It may look a bit weird but if it improves the sound of my system I'll take it.
There are commercial products available that do this safely. It is a "ground reservoir" first proposed by audio visionary Bud Purvine.http://www.stereotimes.com/comm071910.shtmlIs this what you are talking about rollo?
Is this conversation / method akin to this product: EVS Ground Enhancers?
