Hello Face.
They are simple 2-way speakers.
Yes, in most domestic situations, lobing would be a problem at times. As I mentioned, this speaker was built for a specific purpose.....high effeciency for testing noise levels in a system environment. The listening distance for these speakers is pretty far back which also helps and the crossover point in kept low. They will always be listened to on-axis and from a decent distance (12-15 feet)
Lobing is a problem with many speakers and not just MTM designs. It can often be apparent in many multi driver speakers that use low crossover slopes allowing multiple drivers to produce the same frequencies.
Long story short, this effect was taken into account before building the speakers.
