I believe we all can agree on some "truth" we have discovered over the yea :duhrs setting up our systems.
1. Clean power from a dedicated circuit.
2. room acoustics
3. cables make a difference
4. garbage in garbage out, meaning the source is critical
5. mood matters for listening.
6. ones car radio can create emotion as well. It is the music silly.
I think the concept of truth as an entity and as it related to music may have been a little of the Path of where this thread was intend to go, so let me get a little bit closer to the original intent and address some of Charles' points directly.
In the same way that Rich abstractly discussed truth being a relative thing, that concept has some practical applications here. For example , I propose the following responses to Charles' suggested lists of " audio truths".
While I agree that clean power is always a good thing,whether or not it is audible can definitely be a function of the equipment being used. For example a piece with an exceptionally well designed power supply can overcome a lot of the problems we see from less that perfectly clean input power and on the other hand a lower quality mid-fi type system may or may not have the resolving power to hear the difference that better power brings to the table. (if it sounds so-so in the first place, clean power can't help that much.)
2. room acoustics
For the most part I absolutely agree. The reproduced sound will always interact with the environment it is played in. And if that environment is such that the sound waves work against each other you will have problems. But again the system must have a certain level of quality to it before this becomes and issue.
For the most part yes, but with the same system quality caveat mentioned above. But just how much of a difference really depends on the equipment involved.
I don't think anyone can argue with this. A component can never be better that the signal fed to it. I would extend it though to apply to each piece of gear in the chain as a function to all that goes before it. If you have a cr@ppy preamp in between a great source and a great amp, the total output of that will be garbage as well.
.... as for most everything else in life
No doubt, but it is still not the same involvement as a sit down formal listen session (which is a good thing if you are supposed to be paying attention to the road.) This brings up a good point though. There are many different levels of music listening other that sitting in the sweet spot, each of which has its place and each of which cam bring enjoyment to the listener. For example, when I bring a boom box into the back yard to listen to music while I am painting a fence or pulling weeds, the intention is not to become impressed in the music and swept away by the performance and the sound, but rather to simply put a soundtrack to a less than fun task in an effort to make it at least a little less dis-pleasurable. That is a type of enjoyment in its own right although a different enjoyment from what you get from sweet spot listen, but musical enjoyment a valuable none the less. As audiophile many of us at times tend to look down at anything that is not focused dedicated listening as somewhat less important in the grand scheme of thing. when in fact anytime we can enjoy music in and of itself, it is a good thing.
As Pete would say, just my 2 cents.
