Well - here's something to continue the Speaker Cable discussion thread...
I have just finished reviewing the KLE Innovations Essence gZero2 speaker cables from KLE Innovations.
http://www.image99.net/blog/files/fac35e44c003d559714cdd73d86febf9-51.htmlEven though these cables are very skinny they outperformed my Van den Hul d-352 cables with the Furez bananas and by a considerable margin.
They do take a bit of burning in, >300 hours, but it is worth the wait.
A couple of caveats...
- the longest cable they suggest is 4 meters and the shortest made is 2 meter, with the ideal length being 3 meters - like those I reviewed - and then purchased
- to ensure optimum performance, that the audio systems Speaker impedance, especially the average, needs to be >3ohms and that the Speaker Sensitivity needs to be >83db
Other than that, the cables provide across the board clarity and dynamics. They provided a deeper bass response and a warmer and fuller overall tone with a significantly deeper image than the D-352
Just as general comment - I have been playing around with cables for about 4 years and without a doubt the KLE Innovations product range is extremely good. The Harmony RCA Plug range all beat Keith Louis' previous best the Eichmann Silver Bullet RCA by a considerable margin and his cables are definitely performance oriented.
Just google KLE Innovations for complete details
Their current available products seem to be geared for the more "modestly priced" systems - my estimate <$30k, but their Balanced IC's are on the drawing board and more upmarket speaker cables are on their way also.
My System definitely falls into that range ...
NAIM 5i Integrated amp
Gershman Acoustics Sonogram Speakers
Schiit Bifrost DAC - digital input streamed from an iMAC
Simaudio Moon LP5.3 phono stage
Stager Silver Solids IC with Silver Harmony RCA
KLE Innovations Essence gZero3 IC
KLE Innovations Essence gZero2 Speaker Cables
Denon DL 103 Cartridge (mod) on Audiomods arm on Custom TT
Power Cables - DIY Braided Furutech conductors with Sonar Quest IEC.Mains connectors (silver plated copper)
MSRP around $12k
But with the KLEI products it performs way above its price point
Chat Later
