is that a plastic/vinyl stick on?
Yup.
Laugh now,,,, but get back to me if you ever pony up the "whole" $7.50 to try it.
Also, so long as you don't peel it off the wax paper, you can actually demo the chip on the wax paper using some scotch tape and send it back for your "whole" $7.50 investment returned if it doesn't rock your boat.
The only real issue here from my aspect is once you're blown away by the cheap fuse chip, you're gonna want to try the other sizes out. I say "from my aspect" as I have a loudspeaker chip on all 6 loudspeakers and on my subwoofer, plus I doubled up on my mains, placing them directly behind the drivers.
My advise, just laugh me off and leave it at that. That way, we both can laugh.
Cheers,
Robin
