With 'digital' amps, I've found power conditioning very helpful, with no dynamic compression that I can hear. I consider them indispensible. I've used the Haley and an Audio Magic Stealth (upgraded), a PS Audio and the new APC. The Haley is really nice in my system, a little smoother and quieter than the Stealth, but the Stealth is more lively, detailed and dynamic.
That said, the best conditioner I've used with my amps, and especially the Tact 2150, is the Foundation Research LC-2, which is an integrated PC and conditioner. It's made for use with amps, as long as they're not too power-hungry (Transistor Class AB Push-Pull rated to 240 wrms total, 140 for A/B tubes). It sort of splits the difference between the Stealth and Haley---effortless, smooth, quiet and dynamic. Worked nicely with my Aloia SS amp, too. Never tried it with tubes, though.
