... I sure wish someone smarter than me could explain in scientific terms what these suckers are actually doing. Hey, I've got a yard full of rocks... what makes his better than mine Seriously, if I could better understand what they are doing, I might just find far better ways of using them. Inquiring minds want to know...
Alan used to have quite a bit of info. listed on his Facebook page under a posting called "The Art of CBF Tuning." Unfortunately, he is in the middle of re-working both his website and FB page, so I can't find a link for you guys and gals right now. From what I remember, he said that CBF's are designed to tune out (cancel?) the noise and odd harmonics in the electrical circuits of your house. I think the technology he uses involves treating the EMI (Maybe RFI too?) but I'm not tech-saavy enough to know or explain much else.
As far as usage goes, I have traded many e-mails, PM's etc... on the subject with Alan and for the most part the conversation always ends with the same common answer. I'll try to explain it in my own words as best I can here.
Like everything else us audio crazies try in quest for the "audio nervana", every application (E.g.: house wiring, incoming power, the audio equipment itself, acoustics and one's own personal musical/sound preferences etc...) is (are) different, so what works in one person's system, may not work for yours. In regards to the AMD products (even though I know this is not what everybody wants to hear) it ALWAYS comes down to experimenting with placement. From what I understand (from strictly an audio standpoint) you should be able to hear whether any AMD product placement is "in a good spot" within the first 1/2 hour. If you hear a rather dramatic change in your system for the worse within that first 1/2 hour or so, it will progressively give you better sound until it's maximized around that "magic" 21 day timeframe. If you don't get this "bad before good" result, it means you should try it in another place within your home. I only learned of this "bad before good" approach recently, so once I get up enough "courage" (read: patience) to do it, I will be removing and re-installing some AMD products too!
Maybe (?) he (Alan) will see this thread and respond on AN to help clarify things for everyone.
