Bass traps are going up as I type.. I made them to fill each corner of my room, floor to (soffit) ceiling.
They are 2' x 7' for 3 corners, and 1 rear is 2' x 6' 4" because there's a little box there for some hvac stuff.
I used 2" OC703 and layered them from back to front:
1-6", 2-12", 1-18" wide, and 1-24"
Front to back each trap is 12" at its deepest point to the corner.
I'm almost out of OC703!
So, I'm really happy it all worked out. Right now the frames are sitting and waiting for fabric.. The frame will basically just be a cover for the fiberglass... I can remove it and add different types of material if I decide to later. Right now I'm enjoying the absorption... very nice, I don't think I want to add anything...
The room sounds better than ever right now, very emotional and engaging... The whole thing really came together when I sat and listened after the last trap went in... and wow... just amazing. It completes the room.
I still plan to do corner treatments for the upper soffit/ceiling corners and I think I'm done for a while. whew!
