Hey Mike, I told Vinny on Saturday that he would be de-bugging that little amp in about a week's time.
Here's a couple of things to think about:
- If you're going to measure resistors they have to be out of the circuit. You can't just measure them in place.
- Did the kit provide you with measurement points to test your AC and DC voltages? That would be the first place to look. It will help you determine which stage the error is likely to be found in.
- As was mentioned before, check all your solder connections. it is all too likely that you just have a cold solder join somewhere.
- Be very careful of tube amp's when plugged in. They carry lethal voltages.
- Check your trannie wiring. There's usually a lot of wires and they can be confused easily, even when color coded.
- Check the orientation of polarized parts. If one is in backwards it can stop everything from working, especially diodes.
Hey, this is your first project also, right? There's always a glitch somewhere that has to be ferretted out. Tell your son that this will always happen on any electrical project. I would be suspicious even if it DID work correctly out of the box, because there's always something that I missed or did wrong, and that is real experience talking.
Good luck.
