I keep waffling on separates vs integrated... although in the end, finances will likely dictate the end result to an integrated.
I was wondering if people had any recommendations for something in the under $800 realm (unfortunately that's probably pushing it).
Some that have caught my attention are:
Rega Mira 3 (used)
Musical Fidelity A3.5 (used - at the edge of the ole price range)
Music Hall 25.2 (used again - seems to be had for around $400 - $450)
Would consider tube based... although not necessary a remote is nice.
Only "perceived downside" of tubes would be heat and warm up time.
They would be driving Onix Strata Mini's... which is not the most efficient at 86dB, but the 8" woofer has a dedicated/built in amp that helps out. So I would suspect the Rega or Music Hall would be plenty of power.
This would be an upgrade from a Yamaha HT receiver which has been strictly used for 2 ch listening (one uses what they have).
What else - music tastes... it varies...
Not much on the heavy rock side... definitely no metal...
We've been migrating to more and more blues and jazz
Thoughts?
Dave
