I have decided to try out the Furutech GTX, it's not cheap but the design looks amazing. My panel is right next to my stereo, will wire it up with 10 gauge. The GTX and Leviton MRI receptacles will be the ones I will use for power distribution, assuming the GTX live up to their reviews, and I'm sure they will as Furutech has always come through with superior connectors.
On plating, when the manufacturer gets it right it can work out very well. WTB's platinum plating works great for RCA plugs, Furutech's rhodium plated copper connectors are also great. Rhodium can be balanced out with gold. I really don't like the idea of having my cable connectors corrode and have them degrade in performance over time. Sure, some folks will clean them but the fact is many will not, and most probably won't do it often enough. Corrosion can also get into the grain of the metal, penetrating into it. That can;t be cleaned. Now, I'd rather use unplated brass receptacles than nickle plated ones when choosing an economical solution, but unplated male power plugs go downhill pretty quick and if you have the cash for plated connectors I feel it's well worth it and makes for a much longer lasting connector.
