As far as I am concerned, it is all about the sound. Different designs require different power supplies.
Cheers.
I find this comment represents my thoughts, too. For example, I have a pre that is battery powered, and the lack of noise plus product performance does it in spades for me.
The sound of what exactly. The circuit or power supply. What my original question was what would make a state of the art power supply. The design lets say is there. Would the trannie, chokes, regulation of voltage be any more important than the other to achieve ones goal.
As an example would substituting a finer trannie be an example ? Adding sophisticated parts to the design ?
The reason for the post was that IMO we listen to the quality of the power supply more than the circuit design. every time a power supply was upgraded there was a big overall improvement.
My comment was somewhat vague, because the circuit design does dictate the supply design. Class A is different than Class AB1, AB2, B.
Thanks for adding more detail Rollo. I misunderstood.
I believe the power supply is much if not most of what we hear. Of course we hear parts in the circuit design, and even HD, IMD as well.
First, I would think that one should minimize the reactance of the reference supply. This would depend upon the value of RL and tube used, so no hard numbers.
Regulation is important. However, the design of such is very important for proper operation. Sometimes probably better not to even use one.
In a preamplifier, operation is class A, so average current is constant. We need to distinguish between one stage and multiple stages.
With one stage, the transformer is virtually a non player in a properly designed power supply. I know of one nearly retired gent on another forum who uses a 1kw power tranny in each channel, and 150,000uf of capacitance. From decades of experience what a waste
and inefficient, and obviously expensive.
A two stage is much more problematic. I would suggest two totally separate power supplies, including separate power transformers, to eliminate frequency dependent feedback through the power supply itself.
The worst mistake I see are the same schematics/designs being used for all the different tubes. Doesn't work that way.
Cheers.
