Forward firing Onix UFW10 with the PE amp, though I ordered the needed caps to replace the cheap Chinese ones that blew on all the original amps.
I need to find another blown one on ebay and buy it for short money.
Mains are Onix Reference 3 with Skiing Ninja Master Xovers, Platinum bypass caps and fully lined with NoRez.
I heard Mike's Von Schweikert VR44jr and thought my system better on top end, tied in mids, but I really came up short down low. Bill agreed. So that's what set me off on incorporating the sub. The 3 panels behind cover the fireplace, have one in each corner for bass, and on left have panels I slide in front of RPTV screen and glass doored piers flanking TV.
The Siamese cat gets moved to attenuate bad frequencies as needed. Though at 19, she's lost half her weight and doesn't do the job she once did.
