Hey guys. I don't know if you typically post on kit builds here but I just finished a Bottlehead Stereomour that turned out fairly decent. This is my first forray into SET amps and specifically the 2a3 tube.
The amp is basically stock although it is built as a power amp (if you can call 3.5 watts "power") and not an integrated. I hav replaced the parafeed caps with Obbligatos and I have a Mundorf Silver/Oil on order to replace the stock coupling caps. I have also installed a JJ ECC1 gold pin for the stock 12AT7, this made a nice improvement in clarity although the amp is still braking in so that comes into play as well.
The Bottlehead will drive the coaxes of my GR Research V1s. My Dodd buffer hi-passes the signal to the amp at about 140 Hz. The 2a3 drives this load with zero issues, it will play louder than I will need to and I do jam from time to time. One of the cool things about this design that I was unaware of until I heard it is that it has fantastic dynamics even at low volumes (less than 60dB!). I have since been told that this is one of the strengths of the parafeed ckt..
I am still at low hours on the unit, around 120 hrs, but this thing plays great ith my speakers. My amps have historically been the bottleneck in my system, no longer! Here are a few pics (please excuse my poor photography):
System pic:
Best,
Ed
