Thanks tmazz,
I have a ProJect TT and arm that uses the dangly-weight type of anti-skate. I've tried no AS, correct AS and too much AS and get the same impression of lack of air in the R channel. I just did as good of a setup job as I can w/ the ProJect protractor.
Some say azimuth can affect channel balance and some disagree - I haven't played with this - It looks as close to level/perpendicular as possible. What say you?
I haven't yet started working my way backwards w/ swapping cable channels, which could identify a preamp or phono preamp issue. I don't want to swap leads on the cartridge as this was a pita to do on initial setup, but I might want to ultimately.
The problem isn't super bad, but does seem present more than not.
My albums are pretty beaten up, so the TT is not my main source so I'm not too worried about the imbalance thing right now.
-Mike
