Author Topic: The AGN II speaker system build  (Read 2619 times)
Re: The AGN II speaker system build
« Reply #15 on: June 23, 2024, 07:28:18 PM »
The two 6x12 servo sub to servo amp wiring is complete for trials.
« Reply #16 on: June 26, 2024, 06:40:32 PM »
The cabinet shop picked up the AGN Line Array baffles for rework to fit the new planar drivers.
Now the wait begins for them to return.
This is the original audio room setup.  All changed now after the rework.
« Reply #17 on: July 05, 2024, 04:49:00 PM »
The new Monolith 6x12 servo sub towers are complete and wired to the 4-HX300-12OB servo amps.
Checked and the first 2 servo amps are up and running.  Need to wire up the second pair.
So far, so good.
« Reply #18 on: July 05, 2024, 09:20:51 PM »
So far, so good.
Party on!!!
« Reply #19 on: July 06, 2024, 03:22:10 AM »
 :beer:
« Reply #20 on: July 09, 2024, 09:01:35 AM »
The Line Array baffle rework has begun.  Baffle #1 was recut and test fit with the 6 planar drivers.  Good to go.
Now for the second one to be recut and some finish work for the new longer slot and front roundovers.
« Reply #21 on: July 10, 2024, 10:16:40 AM »
The second AGN II baffle is reworked and will be back here next week to install the planar drivers for testing.
Getting close!
« Reply #22 on: July 10, 2024, 03:26:09 PM »
Getting close!
« Reply #23 on: July 17, 2024, 12:10:53 PM »
The line array baffles have returned from rework and ready for new holes to be drilled for the new planars.
Then test everything before doing paint touch-up on the prototype baffles.
