This is an all new official product from Clearwave. This speaker is the next generation after the very highly regarded Symphonia 7R, which was rated "Best of 2013" by Parttimeaudiophile. We feel this speaker is even better and it's not nearly as large! Bass and imaging is outstanding, and we use only top shelf parts. Lets start with the drivers. We are using the amazing sounding 6" Accuton woofer that has the latest generation motor. You can really hear it dig down deep... down into subwoofer territory. The transition to the 1" Accuton inverted dome tweeter is seamless, and here we are using only the best parts in the signal path. The crossovers are hand wired using Supra's top tier wiring... the PLY wiring is used throughout.
Here's the list of features:
Accuton 6" woofer
Accuton 1" tweeter
Low parts count crossover using the following parts:
ERSE air core inductors
Clarity Cap MR in tweeter signal path
Clarity Cap ESA everywhere else
Mundorf Supreme resistor in signal path(tweeter)
Mundorf 10 watt resistors everywhere else
Cardas soldering all point to point from binding posts to drivers
High-end Supra PLY wiring
Cardas copper binding posts with gold plating
Custom engraved binding post plate and port ring to lower resonance.
Double thick 2" baffles with low diffraction 2" deep carved baffle
1" material everywhere else with vertical bracing
Flared port for low noise
Proprietary damping material to turn vibration into heat
All of the above is $2995 with a 15 day audition period money back (less shipping costs).
Try them out and be amazed!
Pictured here is the Standard real Koa or Rosewood veneer with lacquer finish! Most companies would upcharge for all of these features.
Thank you for the interest.
Clearwave Loudspeaker Design
Jed K.
