A LOT depends on your preference and in equipment matching as has been said before. In MY system, the Mullards are very lush in the mids but sloppy and muddy in the bottom. I have other friends' systems where the Mullards are just perfect.
In my particular system, RCA Blackplates seem to be the best balance of great mids, non-rolled off highs, and tight, punchy, extended bass.
Other tubes to consider are GE 5 stars, Phillips, Telefunken ($$$$)
Also remember that in different locations in the preamp circuits, you may find different things work better for you. You may actually end up with a mix of brands. I know in my preamp, the RCA's work best in the gain stages while a Telefunken works best in the power supply regulation.
