Author Topic: No love for the 6550?  (Read 1981 times)
Offline Emil
« on: January 08, 2018, 08:15:49 AM »
Once upon a time many amplifier companies used them but not anymore it seems.
Supply? Sonics?
    --Ice Cube
Re: No love for the 6550?
« Reply #1 on: January 08, 2018, 09:44:33 AM »
The Svetlana ("SED" in the US) 6550C "Winged C" was the standard power tube for VTL, Audio Research, Cary Audio, and many others for many years. SED Svetlana stopped making tubes a few years ago, and the supply of 6550 dried up in about a year as people horded them for these popular amplifiers. The discontinuation of this tube was the cause for AR to switch to KT120 tubes as standard and redesign their entire power amp lineup.
Svetlana's old website lists Antique Electronic Supply (Tubes and More) as their direct sales agent in US, and they still have 6550C for sale, but it is not made in the original St Petersburg Svetlana tube factory, and the internal construction is different, according to customer comment on the 6550C detail page.
American company Tung-Sol invented the original 6550 tube in the 50s.
New Sensor's (Russian made) Tung-Sol 6550 and Gold Lion KT-88 are excellent replacements for the SED 6550C. Shuguang Black Treasure KT88 is also excellent. I think Gold Lion KT88 is much better than SED 6550.
    • Reference components
« Reply #2 on: January 11, 2018, 04:07:53 PM »
Supply? Sonics?
It is a shame. I still have 6 of Winged C 6550s from late 90s/early 2000s. I also have 7 Winged C KT88s from same dates (both St. Petersburg). The two do sound different, but both are easily usable and sound fantastic; just have to tweak the amp to whichever one wishes to use. Right now I am saving them for special times.
I am currently using the SED KT88s, much less expensive, but would one day like to test the new Tung Sol 6550s in my monoblocks. The monos can use either 6550, KT88 tube, and with the high/low tonal switches in the power supply I designed in, all I have to do is flip one, two, or both tonal switches and install other tubes.
I suppose manufacturers are considering the new KT120s, or KT150s? Any input?
Cheers
« Last Edit: January 11, 2018, 04:11:20 PM by steve »
Steve Sammet (retired, but manufacturing "V" ics again)
SAS Audio Labs Test Phono Stage
SAS Audio 11A Reference Preamplifier
SAS Audio 25 W Triode Reference Amplifier
Test Spkrs
"V" ICs
10 parallel 18 ga. speaker wires
« Reply #3 on: January 11, 2018, 05:17:07 PM »
They have the same pinouts, but they draw more heater current, and output more power, which would overload some OPTs that are barely big enough for 6550. KT120 are also heavier tube than 6550, so you can't run them sideways in amps with vertical PCBs like old ARs, even though those have enough PS and tranny to handle them. The later AR amps with horizontal PCB like Ref110 can run KT120s. The new AR Ref75 is able to make 75W with single pair of KT120, said to be a real honey of an amp.
Jim McShane recommends the new TungSol 6550s for amps that used SED 6550. He says his customers are happy with them.
« Reply #4 on: January 12, 2018, 05:37:52 AM »
Carl Marchisotto, owner and designer at NOLA keeps telling me that I just have to get Ref 75 is hands down the best amp to run my Boxers with.
Unfortunately, there are about 8,995 reasons why I can't run out and order one right away.  :roll:
VPI HW-19 Mk IV/SDS/SME IV/Sumiko Blue Pt. Special
Pro-Ject Pre Box S2 DAC/Bluesound Node/Pioneer DV 563A
DigiBuss/TWL PC/MIT Cable
Offline sleepyguy24
« Reply #5 on: January 12, 2018, 07:46:49 PM »
For me when I had my Jolida 502P amp I had the best sound with a quad of NOS matched GE 6550 tubes  that were cryo treated in the amp. The problem for me is the cost. I paid a lot of money for those tubes then one of them blew up. I had to then sell the trio at a loss. I was heartrbroken and didn't want to buy a NOS quad of 6550s again. Then after that I got onto the Tung Sol KT 150s in the Jolida.
My conspiracy theory is that people wanting more wattage numbers just kept pushing the KT88s KT120s and the KT150s. The good ol 6550s got left in the dust. Plus the KT88s look so cool.I remember having a quad of blue Glass JJ KT88s and they looked so big and cool.
« Reply #6 on: January 12, 2018, 08:27:02 PM »
It is also a matter of cost and complexity in the amp design. It is certainly easier and cheaper to design a circuit with a pair of KT-120s as opposed to a quad of 6550s.
And it is also a marketing thing because there is also the prestige of owning and amp with the biggest, baddest tubes on the block that can help sell an amp.
« Last Edit: January 12, 2018, 08:29:01 PM by tmazz »
« Reply #7 on: March 13, 2018, 12:34:55 PM »
  Using [ 20 ] 6550 tubes in the Audio Research DR 250 Mk2 Servo amp. That is why it is sitting there un-used. Besides they were my Maggie Amp. Maggies 3A's long gone.
Offline doug s.
« Reply #8 on: March 14, 2018, 09:50:27 PM »
c'mon charlie - just under $2k to retube that sucker w/premium tubes!   :D (you can use kt-series tubes, not just the 6550's, you know.)  and, you can get inexpensive quads of 6550's for <$100...  what are you waiting for?  ;)
personally, for my "mondo" tube amp, i will hang on to my mesa baron.  "only" 12 power tubes, (5881's or 6L6gc's.  and easy to mod if you want el34's), and four 12ax7's...  it can run 150 wpc pentode, or 50wpc triode, or 1/3-2/3 in-between at 80w or 120w; as well as having 0/-2/-4/-8db negative feedback selection.
doug s.
« Reply #9 on: March 15, 2018, 10:59:44 AM »
  It is the money and then not the money. That AR is best suited for inefficient speakers like Maggies, no more Maggies. One more reason is that the Arion HS500 class "D" hybrid [6H30 input] is much better than AR 250.
« Reply #10 on: March 15, 2018, 11:18:15 AM »
The 6H30 is THE BEST I have ever used in a preamp.  That is what I retubed my insanely modified Cary SLP50B with and there was no comparison to any 6922 variant I had tried.
« Reply #11 on: March 15, 2018, 01:06:24 PM »
   Agree 100% especially if they are those Russian babies.
« Reply #12 on: March 15, 2018, 03:10:09 PM »
Did you have to do any mods t get the Cary to run with 6H30s or are they direct plug in compatible with 6922s?
« Reply #13 on: March 16, 2018, 08:22:54 AM »
  Not to my Knowledge. Should be a direct replacement. Not cheap at $300/pr NOS Reflectors.
Offline doug s.
« Reply #14 on: March 16, 2018, 08:47:08 AM »
you definitely cannot use 6h30's in a circuit designed w/6922's.  there's much info on line about folks asking that very question.
doug s.
