Author Topic: I Confess- I Used Loudness Contour and Liked It. I Also Flipped a Switch...  (Read 5458 times)
Offline rajacat
It's ok since they don't say "treble", they say "attenuator" instead.
"Audiophile approved".   :rofl:
So are you saying all attenuators are created equal or you can't hear the difference? :roll: :-P
Offline Bob in St. Louis
Ouch. No, just that it's ok as long as it doesn't say "bass" or "treble". ;)
What if you want less treble? ;)
Hi Bob,
Depending upon how much highs one wishes to rid of, a little zobel across the speaker terminals might do the trick. It will take some time to figure out the proper R and C values.
Cheers
Steve
