Author Topic: Musica Bella White Pearl Custom Transformer Coupled Output Preamp- only $1,595  (Read 2601 times)
Offline Response Audio
    • Response Audio
High End Design Since 1996
Response34@aol.com
​​​Musica Bella Custom CUST-04
See below for full details.
Custom tube preamp using the 6922/6DJ8 transformer coupled single ended circuit.​
4 single ended inputs
2 single ended transformer coupled outputs
Inquire at Response34@aol.com
- Dynamicap signal capacitors
- Transformer coupled single ended output using custom designed Electra-Print transformers
- Solid core Copper/Teflon signal wire
- 6922 single ended Class A circuit
- High current toroidal PS transformer
- Black Gate power supply filter capacitors
- Choke filtered
- Bybee Music Rail in power supply
- Highly regulated DC filament supply
- NEW VOLUME CONTROL WILL BE INSTALLED UPON ORDER
- High current toroidal transformer
- Relay based input selector
- Precision carbon film resistors
- Gloss White Pearl lacquer automotive like finish
     - 3 coats white base
     - 5 coats white pearl
     - 5 coats clear
1/2"-1" MDF chassis
Selling price: $4,800
New Selling Price - $1,595
Design Engineer
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
    • Response Audio
Re: Musica Bella White Pearl -SOLD
« Reply #1 on: March 28, 2017, 12:18:56 PM »
Design Engineer
Response Audio NY
