Author Topic: Subwoofer Xover to high  (Read 6786 times)
Offline Emil
« on: January 08, 2017, 06:32:03 AM »
Hey guys
The lowest xover setting for my subwoofer is 50 hz or at least thats what it says.
Looking for an inexpensive way to by pass the internal xover such as F-mods but they dont have a setting below 50hz.
Ideas?
    --Ice Cube
Re: Subwoofer Xover to high
« Reply #1 on: January 08, 2017, 08:02:56 AM »
What frequency are you trying to crossover at?  Do you need high pass and low pass for the mains and the subs if you bypass the sub crossover?  How many dB/Octave slopes for the filters do you need?  That info would help with the options.
Offline Emil
« Reply #2 on: January 08, 2017, 08:29:04 AM »
Hi Hal
Planning on running the mains full range and having the sub bring up the bottom somewhere around 40hz.
I dont know. Not even sure what that means :lol:
    --Ice Cube
« Reply #3 on: January 08, 2017, 08:35:25 AM »
Hey guys
Ideas?
Ideas? How about a solution?
Buy speakers that don't need a subwoofer!  :rofl:
KISS Principle, Sir Emil!  :lol:
Offline Emil
« Reply #4 on: January 08, 2017, 09:26:08 AM »
Hey guys
Ideas?
K-Horns are out, Pete. :lol:
My Khornwalls have the 15 inch woofer but dont think the 8 watt   300B can't push them that low.
    --Ice Cube
« Reply #5 on: January 08, 2017, 09:37:31 AM »
Hey guys
Ideas?
Output transformers & the power supply are key. A well designed OPT should go down close to 20 Hz.
You're most likely hindered by the woofer / cabinet design. An original Cornwall can only go down to 38 Hz, due to cabinet (bass reflex) design...
Offline James Edward
« Reply #6 on: January 08, 2017, 10:24:48 AM »
This sounds like a job for a REL Britannia B2 sub in mint condition. The rosewood finish enhances its ability to blend seamlessly with most quality loudspeakers.
Esoteric K-07X
Offline Emil
« Reply #7 on: January 08, 2017, 10:30:49 AM »
I wonder who may have one for sale? Hmmmm :lol:
    --Ice Cube
« Reply #8 on: January 08, 2017, 10:51:17 AM »
Did I not mention that? I'm sorry.  :duh
Esoteric K-07X
Offline Emil
« Reply #9 on: January 08, 2017, 12:23:11 PM »
I think I may have found it.
LP-1 Low pass for $39
http://www.hlabs.com/products/crossovers/index_files/Page384.htm
    --Ice Cube
« Reply #10 on: January 08, 2017, 08:50:34 PM »
Emil is your plan yo use a LP filter to feed the sub and run the 300Bs to the Kornwalls full range? f so this might be usable. But there is no way I would ever use a low priced crossover like this for feed the main amp. Especially with the high sensitivity of your k-horns every little bit of distortion added by the xover will be hugely apparent through your speakers ans all of the great  300B sound will get trampled.
Offline Emil
« Reply #11 on: January 09, 2017, 05:20:40 AM »
I hear you, Tmazz. Speakers will run full range
    --Ice Cube
« Reply #12 on: January 09, 2017, 05:31:58 AM »
Should be OK to try out, not a lot of $ if it doesn't work out. You are correct Emil, that the sub crossover point should be lower than the bottom end on your speakers.
« Reply #13 on: January 09, 2017, 10:27:39 AM »
According to Sound Doctor your sub should come in around 80hz, not much lower. I forget his justification but I am sure it is published online somewhere.
« Reply #14 on: January 09, 2017, 01:22:50 PM »
That might be true if you were doing a true crossover and rolling off the bass to the main amp, as it would keep the woofers in the main speaker operating more in their linear range.  But I would think that if you are feeding a full range signal into a speaker that is good down to 38Hz using a LPF set to 80 Hz would result in too much bass in the 38-80 range. How much would depend on the slopes of the filter and the speaker rolloff, but I am pretty sure it would be too much.
