Author Topic: Woofer Amp  (Read 4697 times)
Woofer Amp
« on: October 22, 2016, 02:51:11 PM »
i  recently decided to go the BiAmp route with my speakers. So I purchased a mindsp and a Crown XLS 1002. This Crown powers a woofer (not a sub per se)  Well it hasn't worked so well to this point. The power amp sounds horrible. It sounds like the input sensitivity is low as I can't get much out of the amp even though it is rated at over 200wpc. It has no b**ls. Any ideas ?
Re: Woofer Amp
« Reply #1 on: October 22, 2016, 03:41:44 PM »
1. Cabinet alignment?
2. Break In amp/woofer
3. RTFM ;)
4. dsp EQ
Re: Woofer Amp
« Reply #2 on: October 22, 2016, 03:50:10 PM »
Did you set the input sensitivity to 0.775V for high gain?
Are the gain controls all the way up?
Re: Woofer Amp
« Reply #3 on: October 22, 2016, 03:54:12 PM »
Yes squared  8)
Re: Woofer Amp
« Reply #4 on: October 22, 2016, 03:56:55 PM »
3. RTFM ;)
4. dsp EQ
1 sealed
2 woofer is 4 years old and is in the same physical config for that time other than a passive xo.
3 hmmm?
4 minidsp sucks, zero support. I will never buy another one of their products.
Re: Woofer Amp
« Reply #5 on: October 22, 2016, 05:55:39 PM »
making some progress. I was able to find gain settings on the mindsp. That helped. Now I am experimenting with the frequencies and slope. The problem is that everytime I change the  slope I have to consider the polarity in relation to the mid/tweeter. been swapping then polarity all day  :duh
« Last Edit: October 22, 2016, 09:33:16 PM by jimbones »
Re: Woofer Amp
« Reply #6 on: October 22, 2016, 06:10:56 PM »
You'll get it Jim!! Speakers rarely jump to. You gotta fight for every inch.
Re: Woofer Amp
« Reply #7 on: October 22, 2016, 06:22:56 PM »
Jim,
Are you using something like Room EQ Wizard to make the speaker measurements?  Or are you using the UMIK-1 with miniDSP?
« Last Edit: October 22, 2016, 06:39:07 PM by HAL »
Re: Woofer Amp
« Reply #8 on: October 22, 2016, 09:33:37 PM »
Jim,
Omnimic
