Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
AudioNervosa
Systemic Development
Digital Audio Devices
Hardware
What software to burn with
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What software to burn with (Read 7781 times)
mfsoa
Obsessively Audiophilic
on:
August 22, 2016, 03:53:13 PM »
So I load the latest dBpoweramp and lo and behold their burner doesn't work on my new PC - They stopped supporting it a while ago.
I really liked that old burner - Can someone recommend a good'n?
I think I tried JRiver once but didn't get too far.
Maybe VLC?
-Mike
Logged
shadowlight
Re: What software to burn with
Reply #1 on:
August 22, 2016, 06:56:01 PM »
Mike,
I am assuming you are talking about burning CD's if that is the case use the built in version in Win7 or higher.
Logged
Out Of My Speaker Cabinet
Reply #2 on:
August 22, 2016, 08:02:26 PM »
I used to use an old version of Roxio, haven't burned a CD in a long time.
I do like the Plextor drives for burning. They only make one optical rw drive anymore, $30 new! omg!
Logged
Audio Neurotic
Reply #3 on:
August 24, 2016, 03:47:34 PM »
I use EAC still.
Not a lot of people ripping from cd these days.
They're all singing "I want my, I want my MP3!"
Logged
_Scotty_
“Sic transit gloria mundi”
Reply #4 on:
August 24, 2016, 08:32:23 PM »
Mike I can't figure out what your problem might be but here is a link to the dBpoweramp CD Writer software download page.
https://www.dbpoweramp.com/cdwriter.htm
If you still have installer exe sitting in the downloads folder you might right click on the exe and open properties and check the compatibility tab. If you originally installed it on Win 7 or 8/8.1 you might try setting compatibility to run the program under the original operating system. Then uninstall the version of the program that is currently on the machine and run the installer exe again which is now set to the earlier OS that the program first worked on. This trick also works on older drivers which the newer OS might not support.
I use both the the ripper and the writer software on my Win 10 HAL MS-2 PC Music Server with no problems.
My truck has a CD player that I use to play classic rock "road trip" music CDs. FM isn't too good anymore.
Logged
Audio Neurotic
Reply #5 on:
September 06, 2016, 04:46:34 AM »
I rip with EAC (though you have to be sure to configure it properly), and I burn with Roxio.
Logged
mfsoa
Reply #6 on:
September 06, 2016, 09:58:13 AM »
I figured out how to use JRiver's burner and it seems to work. Slow and no features though.
Thanks for the tips.
Logged
Print
Pages: [
1
Go Up
« previous
next »
AudioNervosa
Hardware
