Author Topic: Floor bounce question  (Read 4070 times)
Offline Werd
« on: June 03, 2016, 09:06:40 AM »
Is there any correlation between the distance of your subs and the frequency the sub X over is at, and floor bounce? To the listener.
Re: Floor bounce question
« Reply #1 on: June 03, 2016, 09:41:26 AM »
I don't believe floor bounce is an issue with subs as the wavelength at low frequencies is very long.
« Reply #2 on: June 03, 2016, 10:46:56 AM »
Here is a good way to check:
« Reply #3 on: June 03, 2016, 11:20:46 AM »
HAL's link:
http://david-janszen.squarespace.com/blog/speaker-setup-minimizing-the-allison-effect2015321
Floor bounce calculator:
https://mehlau.net/audio/floorbounce/
With sub at 10", ears at 37", distance 8 feet, the floor bounce is at 970Hz, so the sub crossover freq is irrelevant.
Offline Werd
« Reply #4 on: June 03, 2016, 03:39:43 PM »
Ok that was actually very helpful   :lol:. I am being serious.  :thumb:
« Reply #5 on: February 15, 2017, 08:59:01 PM »
HAL's link:
Thanks for the links Rich. Much appreciated.
Cheers
Steve
« Reply #6 on: February 18, 2017, 05:18:38 AM »
Obviously if a sub is down firing, the floor bounce is part of the design. But wait, why do they sound better upside down? Or why do front firing subs sound better when raised off the floor a foot or so?
The traditional wisdom says put a sub in the corner. Nay Nay, I say. Put them in between your speakers away from a corner, and get them off the floor. You may have to adjust the levels a bit, but they will sound faster and cleaner and probably integrate better. Getting them away from a boundary will reduce that boom, making them more articulate.
Try it.
