Author Topic: Cartridge for Sony PS-8750 turntable?  (Read 5656 times)
Offline rpf
« on: December 19, 2015, 09:45:11 AM »
So a young (compared to me :lol:) cousin, a budding audiophile into vintage gear, picked up a very good condition Sony PS-8750 turntable that he'd been seeking for a long time.
And now he's looking for a cartridge, preferably at a modest price (few hundred dollars?)
What cartridge should he look for and where should he buy it?
TIA
Rob
Offline ejk
  • Did I say no dropouts ?
Re: Cartridge for Sony PS-8750 turntable?
« Reply #1 on: December 19, 2015, 09:58:09 AM »
The Sony PS-8750 features a direct-drive servo motor that brings the turntable to nominal speed within a half revolution and provides an excellent signal to noise ratio.
A built-in brake circuit stops the turntable quickly when the stop and reject buttons are activated.
Two separate circuits are included in the servo control system of the turntable; one is the innovative Crystal Lock and the other is a conventional servo system.
The crystal control is not affected by voltage and temperature variations under varying conditions, or ageing, and maintains a precise nominal (determined) frequency.
The Crystal Lock system shows excellent initial drift and load/speed characteristics; however, manual pitch control range adjustment is available for the PS-8750 when desired, by using the alternate conventional servo system.
The frequency generator is composed of a magnetic coating inside the platter - this design feature contributes to an exceptionally low degree of wow and flutter.
The tonearm employs a highly sensitive jewelled trunnion mount for longitudinal and lateral support.
An arm pipe and shell made of carbon fibre suppresses resonance interference.
The photoelectronic circuits employed in the PS8750 eliminate the usual impact of the tonearm caused by a conventional auto-stop mechanism and permit the use of a more sensitive tonearm.
The static insulated dust cover allows correct tracing of light tracking force cartridges.
The cabinet is made from the new acoustic material SBMC and ant-vibration material is used inside the cabinet, minimising cabinet resonances and vibration, and preventing any degradation of tone quality.
Specifications
Type: semi-auto record player
Platter: 32cm aluminium alloy die-cast
Motor: AC servo-controlled motor
Drive system: direct-drive with crystal-lock control
Speeds: 33.33 and 45rpm
Pitch control: +-4%
Wow and flutter: 0.025% WRMS
S/N ratio: 70dB DIN-B
Tonearm: Statically balanced universal
Effective length: 237mm
Overhang: 15mm
Tracking force: 0 to 2.5g
Cartridge weight range: 3-10g (3-19.5g with extra weights)
Dimensions: 458 x 184 x 395mm
Weight: 14.2kg
« Reply #2 on: December 19, 2015, 10:01:51 AM »
At the lower end of the price spectrum I have always found it hard to beat the Grados. And on the plus side they have replaceable stylii, so if someone who is not really used to handling delicate phone equipment should have a little oops, they the whole cartridge is not a total loss.
Since the TT is kind of an off the beaten path model, I would try Needle Doctor. Since pretty much all they sell is cartridges they would probably be the most likely to have somebody on staff who is familiar with that model Sony and what might work (or not work with it.
http://www.needledoctor.com/
Offline ejk
« Reply #3 on: December 19, 2015, 10:02:06 AM »
I just read on the Vintageknob that he should get an MC cart. The manual is on Vinyl Engine
Offline sleepyguy24
« Reply #4 on: December 21, 2015, 01:18:55 PM »
I reached out to members on Audiogon and this is what they said regarding the Sony PS-8750 TT?
A Nagoka at that price is very good , I think LP Gear is selling
them but they have no US distributor at present . Nagoka MP-110 is very good on Classical and at 120$ is a real bargain . Next step up is Goldring 2100 at 230$ which will unravel a symphony bit better than the Nagoka MP-110 but sounds similar, not surprising since Nagoka makes them. Both have a full robust sound pretty much across their range.
If they have a speaker that could use a bit of mid-range emphasis a Grado Red or Blue is good as well.
IMO , the various cheaper AT and Ortofons are a bit bright for classical.
« Reply #5 on: December 21, 2015, 01:44:23 PM »
Jsaliga last year picked a mid-line Nagaoka and liked it but sold to buy a better cart. (He bought it from LP Gear) I've had 2 diff. Goldring's. Got both for a very good price but I didn't like either and ended selling both. I don't know how it would match up with the arm but a lot of folks like AT440MLB
http://www.amazon.com/Audio-Technica-AT440MLB-Phonograph-Cartridge/dp/B00OQUJ1QO/ref=sr_1_2?ie=UTF8&qid=1450734161&sr=8-2&keywords=audio+technica+at440mla
As always YMMV
P-man
« Reply #6 on: December 22, 2015, 06:13:44 AM »
  Good call P-man.
Offline sleepyguy24
« Reply #7 on: December 22, 2015, 06:18:20 AM »
Also I forgot to +1 this comment. When I first got back to turntables and I didn't know about this place I reached out to NeedleDoctor for cartridge suggestions on the TTs I had. They really listened to my situation and gave me some good options that didn't break the bank.
« Reply #8 on: December 22, 2015, 07:37:36 AM »
   He da Man. Helped me. www.robyattaudio.com as well
« Last Edit: December 22, 2015, 07:43:20 AM by rollo »
