Author Topic: Turntables  (Read 20545 times)
Offline topround
Re: Turntables
« Reply #30 on: December 09, 2015, 08:42:35 AM »
Charles,
You might want to try your Vista with slagles stepups for the miyajima.
I ran that combo for a while and it was quite good, of course a better fono pre would help even more.
Do what the big boys do in high end analogue and run a MM phono pre and use stepups. Built in gain for a MC is a selling point for sure, but not really the best way to do it. The passive gain created by the transformer is by far the best sounding IMO, the inductor in the cartridge likes to see another inductor boost its signal, whenever caps and resistors are removed from the signal ,,it only gets better IMO.
If slagles stepups are too dear, than try cheaper ones, there are plenty out there......but IMO slagles are some of the best
Re: Turntables
« Reply #31 on: December 09, 2015, 08:51:18 AM »
Beautiful system, Scott!
What brand are those curvy face tube components in the left rack?
Offline Hugh
    • Angel City Audio
Re: Turntables
« Reply #32 on: December 09, 2015, 02:58:21 PM »
Mike,
How much is the Slagles step-up transformer?
Hugh
Charles,
Hugh Nguyen
Angel City Audio
Offline topround
Re: Turntables
« Reply #33 on: December 09, 2015, 03:34:16 PM »
http://www.intactaudio.com/tran.html
try the silver......yummy
Offline Hugh
    • Angel City Audio
Re: Turntables
« Reply #34 on: December 09, 2015, 03:48:45 PM »
I was there but didn't see anything re silver. :(
The only thing I saw was this.
Phono Step-Up Transformers (SUT's)
Custom designed transformers on a large 80% nickel core wound specifically for your cartridge / phono pre interface. Please understand that these devices are unshielded and will require assembly into a shielded enclosure. We can provide you with some people who can do this task or help you DIY your own.
Priced From $250 each.
Hugh Nguyen
Angel City Audio
Offline topround
Re: Turntables
« Reply #35 on: December 09, 2015, 05:39:51 PM »
silver is available, website just does not show them
and price is a bit higher...................but worth it
Offline Scottdazzle
Re: Turntables
« Reply #36 on: December 09, 2015, 07:44:57 PM »
Those are the Zesto components.  Carolyn Counnas did the visual design which is based on the shape of the grand piano.  George Counnas designed and builds the components.  Great sounding and great looking gear.  I really like pieces that have visual as well as sonic beauty.
Viva Hifi in Vienna, VA
email: vivahifi@gmail.com
Retired
Offline Hugh
    • Angel City Audio
Re: Turntables
« Reply #37 on: December 15, 2015, 07:03:44 AM »
Mike,
Do you have Dave's contact?
Hugh Nguyen
Angel City Audio
Re: Turntables
« Reply #38 on: December 15, 2015, 12:05:22 PM »
Charles,
   Thanks Mike could not agree more.Need to talk to dave.
Offline TomS
  • Yeah, it's just a hobby...
Re: Turntables
« Reply #39 on: December 20, 2015, 04:56:26 PM »
  So what are you using for a TT and phonostage ? running a linn LP12 for mono with grado mono cart.
   For Stereo a Kuzma Stobi S with Stogi S 12"VTA adj arm. Cart now Golden Note. A Miyajima in my near future.
   A Vista phonostage for the Linn and a Loesch & Weisner phono/Pre for stereo. The Loesch needs some repair so was thinking of new phono stage. Looking hard at Miracle audio custom phono. A Parasound or Sim as well.. Would love a Zanden but we need to save some $.
    Looking for a Klyne used but very hard to find. I made a big mistake selling my Klyne SK5A. Live and learn. Hoye !
    Economically fixing the L&W makes sense as it is world class. However the WE 417A tubes are getting rarer and very expensive as we speak. Bummer but life. Then there are 12 more tubaroonies to deal with.  Should I ? Should I not ? What to do.
   Any suggestions ?? I committed to the cart but the PS still up in the air.
Charles,
A Klyne 7PX-3.5 just came available for $2500 ;-)
https://app.audiogon.com/listings/phono-klyne-audio-arts-7px-3-5-phono-preamp-2015-12-20-preamplifiers-37920-kimberlin-height-tn
Re: Turntables
« Reply #40 on: December 21, 2015, 11:34:02 AM »
  Thanks tom I'm on it.
Re: Turntables
« Reply #41 on: December 21, 2015, 11:38:14 AM »
  Actually have a contender I'm evaluating now from a new co called Vu Deja. Tubed with outboard power supply.
   So far very impressed.
Offline Werd
Re: Turntables
« Reply #42 on: December 22, 2015, 03:46:21 PM »
This may sound goofy but what the hell. Has anyone ever tried perfecting a wind-up version of a TT? Unlike a motor that is used to turn the platter.
Probably have to wind it up after a couple of songs but you lose the motor. If you can wind a watch why not a TT?
Re: Turntables
« Reply #43 on: December 22, 2015, 05:13:41 PM »
It's been done...  :thumb:
Offline Werd
Re: Turntables
« Reply #44 on: December 24, 2015, 04:15:05 PM »
What do you guys think if this budget Marantz? belt drive made in Germany for $300
http://www.amazon.com/Marantz-TT42-automatic-Turntable-Cartridge/dp/B005JK64FQ
